Re: H still not starting - Day 5!
Posted by Dan G on April 15, 2010 at 04:43:13 from (208.111.212.26):
In Reply to: H still not starting - Day 5! posted by soybeanjoe on April 14, 2010 at 15:42:24:
Putting new plugs in it today. That will rule out plugs being fouled from fuel additive crap. I'm also going to check firing order with plug wires. Mine were not as what most people describe.
2 - 1
4 - 3
well....it was that way, but they had number 1 at the BACK of the tractor, back to front. I can't believe that is true, but I'll do the TDC check the rotor direction trick.
I believe this is somehow an ignition problem because quick start spray did not fire the engine AT ALL. Even if the carb is blocked, it should sputter a little with the spray.
