Here's an easy way to set your valve lash. Bring No1 piston near the radiator to TDC on the the compression stroke. Both valves should now be closed on that cylinder. Counting from radiator end of the engine adjust valves 1,2, 3 & 5. Set the valves to .017" Cold.
Rotate engine one full turn and then adjust valves 4,6,7 & 8. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
