Re: 1952 Farmall F-cub
Posted by mkirsch on April 15, 2010 at 10:26:41 from (64.80.108.57):
In Reply to: 1952 Farmall F-cub posted by Brad Foster on April 15, 2010 at 05:29:28:
It depends.
Bare tractor with no weights or implements starts at around 1600lbs.
Add 1 set of rear weights, you're at 1900lbs.
Add fluid in the rear tires, you're at 2200lbs.
Add front weights, you're at 2250lbs.
Add a second set of rears, you're at 2550lbs.
Add a front blade, you're at 2800lbs.
