Re: H still not starting - Day 5!
Posted by El Toro on April 15, 2010 at 16:53:52 from (74.103.74.58):
In Reply to: Re: H still not starting - Day 5! posted by Dan G on April 15, 2010 at 15:59:42:
You probably have some plug wires crossed. You still need to bring No1 piston to TDC on the compression stroke. Then see where the rotor is pointing. Place your No1 plug wire there on the cap and to No1 plug, then connect No3 wire to cap and No3 plug. Then do 4 & 2 going cw on the cap. Then see if if will run. Hal
