Super C Throwout Bearing
Posted by KYCASE1 on April 16, 2010 at 07:38:25 from (66.38.63.98):
I just replaced the throwout bearing in a 1953 super c and now the clutch will not release unless the the clutch rod is adjusted to its longest point and the clutch peddle is pushed all the way down. The clutch and pressure plate were not replaced and were never removed from the flywheel. The bearing that I put in the tractor was not an exact match to the one that I removed but was told that it was the updated version. Also the old bearing had to be greased and the new bearing was a sealed type. Has anyone had any experience with this problem? Thanks for any help
KYCASE1
