Cue P. said: (quoted from post at 09:15:44 04/16/10) IH560, Is that a rear view mirror off the touch control levers or something else?
Yes it is a rear view mirror, I am not sure what it is for or off of. My grandfather was always running stuff between pieces of land on the road and he installed it, so he could see behind him for traffic, without always having to turn around.
The reason the plow is mounted all the way to one side is because that is how it is supposed to be set-up, If my grandfather had not put the 140 seat on it I would mount both plows on the tractor. What you see in the picture is just one half of the A-189 two way plow set up. There is a set of levers that mount beside the seat, and behind the gear shift that you use to select which plow you want to lower, but with the 140 seat, you cannot mount this. Also if the plow is mounted in the center then the front lift bracket must be running at an angle, and how does your right rear tire run in the open furrow?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
