Posted by Lmack on April 16, 2010 at 17:58:07 from (74.190.2.70):
In Reply to: Hand Cranking my C posted by DoubleR on April 16, 2010 at 10:02:40:
My dad would take both hands and spin the thing, but he was much of a man to be just 5' 7". I was too small when I first tried to pull up so I learned to push down. Turn the crank till you feel compression. I set the crand at about 1 oclock and push down jumping on the crank for extra speed. IF IT BACKFIRES YOUR ARM IS BROKE. Make sure you have a properly tuned motor. If it is the first time cranking after a rebuild use the starter or pull it off, do not use a crank.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
