Re: fast hitch helper spring
Posted by Erik Dekeyser on April 17, 2010 at 05:39:39 from (161.216.9.225):
In Reply to: fast hitch helper spring posted by rettefowler on April 16, 2010 at 19:26:30:
There is no bracket it just goes into a hole between the fender and the transmission.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
