Re: M-SM carb
Posted by CNKS on April 17, 2010 at 07:18:36 from (216.144.104.128):
In Reply to: Re: M-SM carb posted by randy hall on April 16, 2010 at 19:21:23:
I know that -- Note that I put "fixed" in brackets for lack of a better word. At 5 turns out you cannot add more fuel, but you can reduce it. At 5 turns, and I believe even 4, the tip of the needle is not in the jet. It apparantly reduces the fuel as it gets closer to the jet. I have a Super H and a 460 with that basic carb. When I rebuilt the one on my Super H, I adjusted it like an H or M carb, in until rough, out until smooth. Started cutting out with nothing more than a slight incline -- then I read the manual.
