Posted by rustyfarmall on April 17, 2010 at 12:48:51 from (209.152.78.140):
In Reply to: M Belt Pulley Assy posted by Bouncer on April 17, 2010 at 11:46:38:
Bouncer said: (quoted from post at 11:46:38 04/17/10) Can someone please tell me how to remove the belt pulley assy from the tractor? I took out all the bolts on top, but I see a threaded bolt that appears to be coming up from underneath on each end. Do you have to remove the hyd pump and then reach up in there and take those two out from inside?
Thanks!
Those threaded bolts are nothing more than alignment studs. The pulley assembly should just lift off of them.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
