Re: H Starting Problem
Posted by Bengt Erik Eriksson on April 17, 2010 at 16:27:57 from (90.229.246.11):
In Reply to: H Starting Problem posted by Doug Kieta on April 17, 2010 at 14:41:01:
Iḿ not shure if it is relevant but Is the governor working properly? throttle correct set?
are the float giving the right level? attach a hose on drain and check against mark on body.
If you get it runing on gas you can check for leaks by spraying ether around gaskets etc.
and ofcoures are mainjet giving proper amount of gas?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
