Posted by Tom Fleming on April 18, 2010 at 03:21:17 from (67.20.229.132):
Just got done rebulding the PTO housing on my 1942 H. Had a bit of trouble finding seals and bearing. I learned something that may help.
First off, about 6 months ago, I had to replace the left side seals, pinion shaft, and brake drum on my 1946 A. When I was done, I had an extra pinion shaft bearing in good shape. Well, turns out that the pinion bearing also fits the PTO on the H. Interesting as it is listed as a different part number. However, the bearing is identical.
Napa part number for the PTO housing seal is 13676. Original IH seal application was actually 2 seals, leather with steel case/spring. Replacement parts from IH were $30+. I installed 2 of the Napa seals (with a bit of grease between them) for $16 (each seal was $7.95).
In any case, I just wanted to share of bit of learned knowledge. What was looking to be a $75-$100 parts investment turned out to be under $20. Granted, I had the pinion bearing on hand, but interesting they are the same bearing.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
