Posted by Wardner on April 18, 2010 at 08:36:03 from (207.69.139.155):
In Reply to: schram ih posted by rich cartman on April 18, 2010 at 04:44:47:
Schramm is still in business although they no longer make the self- propelled compressor. They were, and still are, principally involved in water drilling equipment. The engine/compressor was their own design and fitted to an IH chassis. They were frequently seen on road building projects where ledge needed to be drilled and blown up. They could get close to the rock drill. This reduced set up time and improved the quality of the compressed air. That means PSI and CFM for an equal sized compressor. I suppose they also saw some light duty tractor service on construction sites. That might include dragging blasting mats.
They met a need when air compressors were heavy and bulky. They would require a 4wd truck or standard tractor to move them around. The 4wd truck was not widely available as they were not built by the OEMs. So if you needed a tractor anyway, why not reduce the drilling air supply down to one unit
This dual use engine concept goes back to at least the Model A Ford and most likely to the Model T with a company called Smith. It was carried forward into the '80's and '90's with small block Ford V8 engines. They were quite popular but I can't remember the brand name of the compressor. Nearly all portable compressors nowadays are screw type rotaries. They are more efficient and have a longer service life .
This post was edited by Wardner at 09:19:07 04/18/10 3 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
