Re: H Starting Problem
Posted by Janicholson on April 18, 2010 at 09:03:18 from (64.61.211.135):
In Reply to: Re: H Starting Problem posted by Doug Kieta on April 18, 2010 at 06:30:05:
I firmly believe the issue is in the carb. There should be fuel to the intake if there is vacuum on the inlet when cranking. There are several items in the mix.
The fuel strainer at the carb inlet.
The seat of the needle and seat (float control valve) can be plugged (above needle)
The float can be touching the side of the carb lower housing and binding in the shut position
The Needle can be stuck in the seat.
The float could be adjusted so low that the needle cannot open.
The main jet could be plugged (or its passages) to the venturi
The venturi could be in wrong, or missing! They hare fragile old pot metal and often decay/oxidize.
These issues can and have caused no fuel at the combustion chamber. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
