Posted by riverbend on April 18, 2010 at 10:26:12 from (74.46.177.253):
In Reply to: H Starting Problem posted by Doug Kieta on April 17, 2010 at 14:41:01:
It sounds like you are getting fuel to the float bowl.
I don't have a manual that shows the carb on a Super H, but if you close the choke and crank the engine half a dozen turns or so, will fuel drip out of the weep hole in the bottom of the carb inlet ? Or if you put you hand over the inlet and crank the motor, Do you get fuel on pooling in the bottom of the carb inlet ?
If not, look for a blockage between the bowl and the emusion tube well. Can you blow air backwards through the main jet ?
