Don't know if we call the front of transmission in the same place, but something else to check is the jaws and shift lever on the seasonal disconect if tractor is equiped with one. T shaped plate on bottom of center housing just in front of the transmission rear end housing. If the plate has a short lever with 2 bolt holes to change position the tractor came with one. You can also look in with plate removed to see if the pto shaft stops turning under load on toward front of tractor and go from there. Only problem is transmission oil will come out when plate is removed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
