Re: super a hard to start when cold
Posted by Lmack on April 18, 2010 at 19:04:30 from (74.190.2.70):
In Reply to: super a hard to start when cold posted by kds on April 18, 2010 at 18:44:30:
Got to be a carburetor problem. As a work-around try turning off the gasoline valve at the tank when you shut it down until you can clean the carburetor. The float valve may have some trash. Try cleaning the carburetor with attention to the float valve. If it hasn't been cleaned in a while you will need a kit which will include a new float valve. Be sure you know the make before you buy the kit because three different carburetors were used at different times.
