Re: Farmall H, kills
Posted by El Toro on April 19, 2010 at 14:18:43 from (74.103.74.58):
In Reply to: Farmall H, kills posted by Tractor Tim on April 19, 2010 at 11:52:50:
Disconnect the gas line at the Carb and see if you have a full stream of gas. Trickle means you have blockage in the tank. You may need to open the main jet adjusting screw near the bottom of the carb. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
