Re: plow hook up
Posted by Wardner on April 19, 2010 at 17:40:15 from (207.69.137.43):
In Reply to: plow hook up posted by Michael Kennedy on April 19, 2010 at 12:24:46:
third party image
You need something like this. This will work but is meant for the Cub two way plow. It raises and lowers the drawbar when it is in the reversed position. It is called a draft control. For proper plowing, the lever needs to lower the drawbar so that it nearly scrapes the ground when the right wheel is in the furrow. That should give you nearly eight inches of plow depth. If you lose traction, you can raise the draft control.
