Hi Ben, the B414 remote outlet that can be controlled by 3pt lever is only single action and a loader bucket requires a double acting cylinder. The proper way to hook up a loader on a B414 is to buy a set of hydraulic control valves, mount then on the loader frame by the right side of the steering wheel. Cut a section out of the high pressure line from the hydraulic pump and connect this line to inlet of hydraulic control valves, connected outlet of hydraulic control valves to remaining section of the high pressure line that goes to the hydraulic reservoir under the seat. If the hydraulic control valves have a low pressure dump line connect this line into the hydraulic filler plug behind the seat.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
