Posted by mkirsch on April 20, 2010 at 04:44:17 from (64.80.108.57):
In Reply to: 450 and plow posted by Chris450 on April 19, 2010 at 19:19:54:
On a lot of plows you can remove the rear bottom and move any tail wheel that there might be up to the next bottom, to reduce the load.
You might not be able to do this on a 412 plow because it's a Fast Hitch plow and it may throw the line of draft off. That is, the load from the plow will pull off to one side of the tractor, making it impossible to keep straight.
Try it first, anyway. If you're only plowing a small area and the ground is decent you can live with going a little slower.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
