Re: Hydraulics on a 1944 Farmall H
Posted by Zachary Hoyt on April 20, 2010 at 14:03:40 from (74.33.203.67):
In Reply to: Hydraulics on a 1944 Farmall H posted by Bigs on April 20, 2010 at 13:22:14:
The belly pump, which is the stock setup, only runs when the clutch pedal is back, but it shouldn't matter whether you're in motion or not. The cylinder leakage is a separate problem and can be fixed by either rebuilding or replacing the cylinder, or maybe tightening any loose parts if you're lucky.
Zach
