Re: water in oil c
Posted by Janicholson on April 20, 2010 at 15:06:41 from (64.61.211.8):
In Reply to: water in oil c posted by Dale L on April 20, 2010 at 14:15:27:
Jeff Z is correct.
If it is an engine that is running well and not using oil, I would repair the head gasket and be on the job.
I use copper coat spray on both sides. A hang it on a wire and spray until covered, not dripping off.
Then wait until it is tackey (five minutes or so) and assemble. Retorque when it has been operated to temperature once, then set valves again. Jim
