Since the H only puts pressure to one side of your cylinder, it may be the cylinder is OK but was full of fluid. After several cycles oil may quit coming out of the open end.
The next thing to do is to get a plug and drill a small hole in it and use it to plug the open end of the cylinder. The hole will keep most dirt out but let air in and out. It is even better if you buy a screw in filter for the same purpose but they can't be found everywhere.
Of course if you want to use the hydraulics while stopped you have to shift to neutral and let the clutch engage, then the hydraulics will work again. It's not too bad when you get used to it, I bale hay that way all the time.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
