Re: Farmall Super A Wheel Rim Issue
Posted by Andy Martin on April 20, 2010 at 15:44:24 from (199.197.2.156):
In Reply to: Re: Farmall Super A Wheel Rim Issue posted by Mr. Dan on April 20, 2010 at 05:01:19:
You don't really need grade 5 in this location. Plain grade 2 will hold just fine.
If you have the space, save your old rim. When the other one goes bad a welder can piece the two together for much less than a new rim.
