Re: IH 674 no reverse.
Posted by JimB2 on April 20, 2010 at 18:01:47 from (99.240.236.11):
In Reply to: Re: IH 674 no reverse. posted by docoliver on April 20, 2010 at 17:48:10:
Doc, did anything happen to the sheet metal around the Hi/Lo/Rev lever that would prevent the lever full travel to Rev position? As a test, you could loosen the sheet metal and allow the Rev lever more travel rearward. There are adjustments under the shifter mechanism. An as Cat Guy said the shifter shaft into the trans can twist off. Some mechanics change via taking MCV & Hydraulic pump out and cutting a wrench handle off.
JimB
