Re: Front wheel assist
Posted by mkirsch on April 21, 2010 at 05:24:28 from (64.80.108.57):
In Reply to: Front wheel assist posted by ryanwheelock on April 20, 2010 at 13:01:12:
I don't know about underpowered, but I've heard that you need a football field to turn them around.
Now, if you know a master toolmaker with the equipment, there's no reason you couldn't add MFWD using a heavy DANA or ROCKWELL steering axle. The L-shaped gearbox that transfers the power up out of the belt pulley hole, out and down the right side of the tractor can be fabricated from plate steel. The difficult part would be getting the gear ratios correct.
