656D 3 point Hey Allan in NE need help
Posted by farmalljosh on April 21, 2010 at 07:34:58 from (69.128.228.143):
Well Allan, finally got the time to tear the top link bracket off and have a look see. What I found was the draft sensing lever coming up from the bottom was loose and just laying forward. From the parts diagram the u-joint type strap that goes around the bottom shaft is either falling off or half way off as I cannot pull that lever all the way up. Now the big question, how do I go about getting to that to get a new strap clamp back on? When I do get it back on how is it adjusted against the draft lever in the pick you sent me? Do I have to take off all the seat and 3 point lift assembly? Any help would be appreciated
