Posted by Wardner on April 21, 2010 at 08:02:58 from (207.69.137.26):
In Reply to: Front wheel assist posted by PORKY B. on April 20, 2010 at 13:01:12:
mkirsch said: (quoted from post at 18:24:28 04/21/10) The difficult part would be getting the gear ratios correct.
That's just math and requires no heavy lifting or significant crainial exercise. You could lay out the fixed values and plug in the variables on a spreadsheet. Just have to be careful to slightly overspeed the front axle and make sure you are using the loaded radius of the front and rear tires.
My 660 Elwood turns tighter than my standard wheelbase pickup.
There are other ways to get FWA. Pull power from one bull pinion shaft and install a locking rear drive. Or you could do it like the Ford County tractors built in England. Run two driveshafts from the rear up to the front right-angle gearboxes/spindles. Or cobble up two H's and build an articulated H. Or do it like that tri-axle JD 720.
This post was edited by Wardner at 08:13:33 04/21/10.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
