Posted by Owen Aaland on April 21, 2010 at 10:45:44 from (65.165.246.74):
In Reply to: Bull Pinion removal posted by tambrosi on April 21, 2010 at 04:37:04:
Kevin in MI said: (quoted from post at 11:35:57 04/21/10) So I do have to take the axle housing off to pull the axle, or just the outter axle bearing?
You can do it either way. If you remove the housing the axle just has to slid out of the bull gear. If you remove the outer axle bearing cap you need to push the axle out of the bull gear, the inner axle bearing and slid the outer bearing out of the housing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
