Re: Strange battery issue with Farmall A
Posted by mkirsch on April 22, 2010 at 04:54:36 from (64.80.108.57):
In Reply to: Strange battery issue with Farmall A posted by Robby_H on April 22, 2010 at 04:44:46:
How are you confirming that it is correctly wired? Did you have someone else check your work?
I ask not because I wish to cast aspersions on your work, but only because we all tend to get "blinders" when it comes to checking our own work. I've lost count of the number of times I've "checked" a particular detail, only to have something not work. Just as I'm about to chalk it up to black magic and voodoo curses, someone comes along and says, "Hey you have that wire in the wrong place!" But, I "checked" a dozen times and I could've sworn it was right!!!
Next, does the generator charge the battery? It should show a charge on the ammeter even with the light switch on L.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
