Posted by John T on April 22, 2010 at 05:04:25 from (66.244.97.31):
In Reply to: H Ammeter Hookup posted by Doug Kieta on April 22, 2010 at 03:13:57:
You POLARIZE the genny by momentarily flash jumping BAT over to GEN/ARM NOTTTTTTTTT FLD
Are you at Pos or Neg ground???
The genny can still charge at EITHER polarity (Pos or Neg ground) once polarized HOWEVER if you swapped polarity the ammeter will read bass ackwards and require a lead reversal to make it register properly.
If the ammeter is wired correct if you turn on lights or ignition NOT running it should swing over to - discharge. If it does the opposite its leads need reversed or else reverse batery polarity and re polarize the genny BEFORE start up.
You need to insure correct wiring,,,,,,,,determine Pos or Neg ground,,,,,,, Correctly Polarize before start up,,,,,,,see what happens.
Run my Troubleshootign procedure to see if non charging is a genny or VR problem
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
