Re: fresh engine
Posted by mkirsch on April 22, 2010 at 05:05:41 from (64.80.108.57):
In Reply to: fresh engine posted by 706 Farmall on April 21, 2010 at 19:27:14:
Cranking the engine with the starter to "prime" the oil pump is just as bad as trying to start the engine.
The point of priming the oil pump is to make sure oil is flowing to all the moving parts BEFORE actually moving them.
If you're cranking the engine with the starter you are defeating the purpose, and you may as well hook up the coil wire and see if it'll fire.
