You may have a battery drain. Charge up the battery then disconnect the battery ground and let it sit a day or two then reconnect the ground and see if the engine will crank and start. If it doesn't you should have that battery load tested or check the electrolyte in each cell and compare the readings using a hydrometer. Should get a reading around 1.260 if one cell reads 1.100 you have a dead cell. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
