If the terminals are warmer than the battery box adjacent to them, they are likely to be either in need of cleaning, or the battery is indeed bad. Check two things: charging voltage at 3/4 throttle (should be 7.2 volts, or between 7 and 7.4) If it is not, it may need to be more adequate diagnosis. The second is the battery itself. Charge it with a good charger that will taper charge it to full. (or a 2 amp charger for 5 hours or so) Then (with it disconnected from one terminal of the tractors system) wait for 24 hrs and check the voltage across it. It should be in the 6.4 to 6.5 volt range. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
