Posted by IronAddict on April 22, 2010 at 06:04:54 from (174.130.23.110):
Hello all I am rebuilding the second of my 3 W-4's. The first one went so smoothly. Only needed the basic overhaul kit (sleeves and pistons) I figured the second would be similar. ..not so lucky! After checking out the crank I decided that it should be ground so I had that done and bought the new bearings. While that was at the machine shop I was preparing to install the sleeves and noticed a crack in #4 cylinder. So I tore down the motor of my 3rd W-4 and found that block is ok. With all this time and money invested I'm thinking that I really should replace the cam and lifters because they are a bit rough looking! Does anyone here know where I can get them. I have been searching the net with no luck. May be a "dealer item"? Thanks all!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
