Re: Help from any 300 experts?
Posted by bkpigs on April 22, 2010 at 09:43:30 from (12.69.254.226):
In Reply to: Help from any 300 experts? posted by EKP60 on April 22, 2010 at 09:30:06:
The PTO may be disconnected. Underneath the tractor is a seasonal disconnect. I believe you have to loosen (or remove, been too long to remember) a bolt that holds the "lever" in place. The other option is that the drive gear for the PTO shaft may be removed (although very unlikely). This is not too bad to put in if you find the replacement.
As far as the TA goes, the tractor will need to be split into 3 pieces to replace or overhaul the unit.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
