Re: fresh engine
Posted by Rootsy on April 22, 2010 at 11:43:52 from (24.247.111.162):
In Reply to: fresh engine posted by 706 Farmall on April 21, 2010 at 19:27:14:
ALWAYS prime... I prefer to do it in a manner where the rotating assy and valve train are static such as just priming the oil pump... With the time and money invested I don't want to take chances on anything...
Most of what I put together makes a lot of torque and turns a lot of rpm... zero failures thus far (crossing my fingers).
A good assy lube is a necessity. It protects bearings, bushings, etc during assy while turning the engine over to assemble. Light film of oil applied by finger tip on the rings...
One of the worst things you can do is crank an engine excessively with only assy lube for protection. Especially if it doesn't fire right off...
