the main load jet is the one on the bottom of the bowl, there is an idle mix and idle speed set up on the top. set the idle mix about 1 and 1/2 turns out. set the main load jet 3 and 1/2 turns out. that should get you in the ball park. start the tractor and let it get goood and warm. then set the idle mix till the tractor runs smooth at idle and adjust the speed screw till you are happy. then i run the tractor at wide open throttle and turn the main load jet in till the motor just starts to change sound, then out 1/2 turns. if you are gonna work her hard, open it another half turn out.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
