Re: 424 wont run
Posted by El Toro on April 23, 2010 at 04:09:04 from (74.103.74.58):
In Reply to: 424 wont run posted by RHeimiller on April 22, 2010 at 18:55:56:
When you bring No1 piston to TDC on the compression stroke check the valves on that cylinder to see if both are closed. Are you sure the plug wires are in their correct firing order on the distributor cap? Sounds like something may have jumped time like a sheared woodruff key. Hal
