Re: Timing J4 Mag to Engine
Posted by 47H on April 23, 2010 at 08:17:46 from (76.164.179.49):
In Reply to: Re: Timing J4 Mag to Engine posted by Nebraska Cowman on April 23, 2010 at 07:50:23:
After installation of the new mag it clicked once while I was turing the engine the required one turn back to TDC. Seems like at about 3/4 the way throught the turn. Yes the tractor did run. I just bought it from the widow of my deceased cousin. The reason I am doing this is the original mag had been by passed with a regular coil. It was very hard to get started but ran fine. I checked the old mag at the impulse coupling had failed. I am in the process of installing a new mag, all new wiring, switches, battery and cables, plugs and wires,rebuilt generator and new regulator. I should mention 6V. I love using these old tractors, but want them to be maintained as they were from the factory. Any way, when you say a tooth or two off are you taling about in the mag or the engine? What is the fix?
