Re: Strange battery issue with Farmall A
Posted by kwsupera on April 23, 2010 at 09:11:54 from (75.147.84.245):
In Reply to: Strange battery issue with Farmall A posted by Robby_H on April 22, 2010 at 04:44:46:
One other thing you can do to see if the battery has a bad cell, which would cause the issues that you describe. Take the caps off the battery while it it charging, either on the tractor, but this is much easier if you hook a charger up to it. If you look in the caps and see a lot of bubbles coming up your battery is bad.
I think the battery is your whole issue here
