Posted by rustyfarmall on April 23, 2010 at 11:02:39 from (209.152.78.140):
In Reply to: h stearing gears posted by Howard Junkin on April 23, 2010 at 07:17:58:
Howard Junkin said: (quoted from post at 07:17:58 04/23/10) I'm fixing the stering on my h. adding a schwartz wide front. but I found that there is slop in the stearing gears. to get this out is it better to change both the gear and worm gear? or does one wear more than thother?
thanks howard
You should be able to pull the gear off, rotate it 180 degrees and put it back on. It is possible though that this has already been done, and then you need to replace that gear. You also want to inspect the condition of the bearing on the worm gear shaft, and also make sure that big pipe plug that holds the worm shaft in is snugged up good.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
