Re: Ammeter question
Posted by Bob M on April 23, 2010 at 17:11:09 from (67.240.166.49):
In Reply to: Ammeter question posted by alannpa on April 23, 2010 at 16:20:44:
Most ammeters' terminals are unmarked. Or perhaps one terminal was marked with a dot of ink which is now long gone...
Not to worry however. Simply connect wiring to the ammeter however it's handy. Now turn on the lights or ignition. If it shows discharge you are all set.
But if it shows charge, simply disconnect and swap the connections. (For safety remove the battery ground terminal while making the swap!)
Unfortunately there's no way to recalibrate/clean the original ammeter - it's a sealed assembly. But new repro ammeters are readily available and inexpensive.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
