Re: will a cub one bottom plow fit my farmall A?
Posted by mkirsch on April 23, 2010 at 21:18:39 from (64.80.108.57):
In Reply to: will a cub one bottom plow fit my farmall A? posted by thndrbird71 on April 23, 2010 at 18:57:12:
The biggest problem with mounting it on an A is that you probably don't have any lift mechanisms whatsoever on the tractor.
Mounting the plow itself is pretty simple, as it is only two bolts into the drawbar. However, with no way to lift the plow out of the ground or control how deep it plows, it will be worse than useless.
