Posted by toro in texas on April 23, 2010 at 23:07:39 from (67.216.252.175):
In Reply to: timing a 504 farmall posted by skye farm on April 23, 2010 at 04:02:13:
My manual says 22 degrees for engine numbers prior to 4484, 20 degrees for engines numbered 4484 and up. 25 degrees for C153 LP gas engines.
Also heads up incase you didn't know...if you happen to have low oil pressure the C153's oil pump's bottom plate is prone to warping, leaking, and loss of pressure. It's a pretty easy fix and discussed in these archives. Good luck
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
