Posted by gene bender on April 24, 2010 at 04:31:54 from (207.177.56.155):
In Reply to: A question posted by rgorton on April 23, 2010 at 17:49:47:
The level plug is behind the rod going to the left brake. Drain is under the right diff housing on the drivers side. I would drain then put a gallon of diesel fuel in and drive around a little bit then drain that out and refil with 90-140 cause with the mower you will be using it pretty good. I would also drain the pto assy and flush it also. When refilling fill the pto assy. When tractor runs lube is thrown up to the top side of the tranny case then a channel in the tranny case lets it run back ionto the pto assy but over the yrs that passage can get plugged thats why to check the pto from time to time to make sure its full as your mower will be using it hard. Great unit for mowing enjoy.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
