Posted by gene bender on April 24, 2010 at 04:51:01 from (207.177.56.155):
In Reply to: Gene Bender posted by 47H on April 23, 2010 at 19:24:38:
Rhe mags cap shows @1 position for that plug wire. Make a mark with black magic marker on the body of the mag where that tower is. Now remove the cap and wires from the plugs. I like to remove all the plugs so the engine will turn over better. Now with the plugs out put your finger in @1 hole. When you turn the engine over you can see where the rotor lines up and snaps this will tell you if either the mag is off 180degrees or tha rotor gears got changed. On the Cub ya cant see the piston of even find it but turning engine over and watching rotor jump when it fires you can tell if mag is in time as you will be able to see the other positions snapas the mag fires the other three cycl. Thatss the way i do all the little I-H when i get a service call tells me rite now if the fire is in time with TDC last one was a 340 found out the wires were put back on wrong. You never know when someone has changed whatever this way i know i a hurry where to go to fix the problem. If ya still have trouble give me a call 319-430-3907 as always glad to help.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
