Posted by D Slater on April 24, 2010 at 15:04:06 from (72.65.153.42):
In Reply to: Torque Amplifier 101 posted by toro in texas on April 23, 2010 at 23:33:19:
With no speed change when handle is shifted. If tractor freewheels with no engine compression hold back going down grade or will roll off when parked on a grade, with transmission gear selected the same direction as the down grade. Then the T/A clutch would not be engaging or holding for some reason. If tractor doesn't freewheel and is hard to shift out of gear sometimes the T/A clutch is not releasing to let T/A shift to low or T/A range. If tractor stops when T/A handle is pulled back the parts that lock T/A unit for T/A range are bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
