Posted by D Slater on April 24, 2010 at 18:31:08 from (72.65.153.42):
In Reply to: Farmall 460 Shifter posted by Puller504 on April 24, 2010 at 16:57:54:
Regular M shifter won't work, the piviot point to the end of shifter that goes in shift forks is shorter. If wanted a 460 type shifter could be made shorter and bent to any place wanted if you could shift and clear everything. If you want to do some bending a shifter from a 300 to 560 and some others can be used unless my memory is off. Some bolt on shifter and shift towers that have a lower piviot point can be found and made to work. For the same upper length shifters and the same transmission a lower piviot point means the top of shifter moves more with less resistance, compared to a higher piviot point that takes more pressure to move shifter but top end moves a shorter distance. On the 460 type IH made the shifter longer above the higher piviot point to overcome the leverage lost. That wasn't the only reason for the shifter design though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
